NOTE: I had battery disconnected for a bit yesterday and have pulled and reseated every fuse in the vehicle.
Jumper as you note STI to upper right (as I am looking in the end) of the connector.
Turn key to on and check engine light flashes what seems to be 3-3---1--3-3. Dash represents relative length of the pause between numbers.
It is hard to tell if there is a first single flash because all the lights come on and off in the self-test, so it may be starting with a 1-. I cannot tell.
Did this three times with the same result.
SPONSORED LINKS
Friday, January 29th, 2010 AT 11:30 AM
