1994 Ford Probe No spark issues
JERRYSPACRAT
Electrical problem
1994 Ford Probe 4 cyl Two Wheel Drive Manual
I recently replaced the head gasket on a 2.0 liter Ford Probe. The timing is correct and everything seems in place. When we went to start the car there was no firing of the plugs. We have checked a few posible problems...connections, wires, etc. The car ran fine prior to overhaul, so it is confusing at best. Wondering what to look for next. Thanks...Jerry
Feb 28, 2010 at 2:30 AM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Feb 28, 2010 at 10:07 AM
