1995 Ford Probe no spark
123,750 MILES • 6 CYL • FWD • MANUAL
ROY489
i have a 95 probe gt , wouldnt start, no spark. so i put a new distributor on it and didnt work , i change the Crankshaft position sensor stilll dont have a spark, i check the fuses,relays , timing belt looks good,when i put the key on the check engine light dont come on and i thought that the computer was bad. i replaced the computer and still dont have a spark.i dont know what else could it be.
Apr 8, 2009 at 5:22 PM
  • 75,988 POSTS
Do you have power to the distributor? Also did you test the coil's primary and secondary winding resistances-
Apr 8, 2009 at 6:37 PM
ROY489
no i dont have power to the coil's, i check the connector with a test light and i found out that doest have power.
Apr 9, 2009 at 3:47 AM
  • 75,988 POSTS
Are we talking battery voltage to the coil/s or the high secondary voltages going to the plugs.
Also test the ignition control module and crankshaft position sensor.
Apr 9, 2009 at 10:43 AM
