Ford Heater Never Gets Hot, Gauge Cold
FORD
KRIEG17
Heater blows but never really get hot, also temp gauge is always stuck on cold. Just want to get an opinion this. Could it be heater core? Thermostat?
Thanks
Jan 21, 2007 at 4:20 AM
BACKYARDMECHANIC
  • 337 POSTS
Most heat problems (or lack of) is usually related to the heater core becoming clog. However I don't think this is the case with your car. Since the car is not running at proper temperatrure , I would suspect that the thermostat is stuck open or has been removed.
Jan 22, 2007 at 1:46 AM
SCHMELLEY89
i also have this problem, i own an 82 150 and not only do i have problems with the heater not blowing hot enough, i think i have a major draft comming frome somewhere.
and my temp gauge never works either, but my odometer never does either.
i had my fan go out and now its directly wired to the battery and i noticed that my heater core doesnt stay warm for more than 20 seconds after i turn the key off.
Jan 22, 2007 at 2:23 AM
Suggested Repair
Because the engine is not reaching normal temperature, check whether the thermostat is stuck open or missing and replace it if needed. A clogged heater core is less likely until the engine runs at the proper temperature.
Conversation Summary
The owner reports that the Ford heater blows air but never gets truly hot and the temperature gauge stays on cold, asking whether the heater core or thermostat is at fault. The expert says a clogged heater core is a common heat problem, but here the lack of proper operating temperature points to a thermostat stuck open or removed. A second owner describes similar heat and gauge issues on a 1982 150, but no further diagnosis is given.
