1994 Ford F-150 Temp Gauge Stays Cold
ACESHIGH717
  • 24 POSTS
I recently made a 300 mile trip and my temp guage never left cold nor the engine overheat. I replaced the temperature switch, but the guage still barely clears the cold mark. What else can I check?
Thanks so much in advance
Dec 7, 2006 at 9:06 AM
ACESHIGH717
  • 24 POSTS
Sorry, I forgot the year and mileage....1994 and has 125,000 miles.
Dec 7, 2006 at 9:16 AM
BOOTDOG
  • 665 POSTS
the problem is either the thermostat, or the gauge itself. i would change the thermostat first, it's alot cheaper than the gauge.
Dec 7, 2006 at 10:57 AM
Suggested Repair
Replace the thermostat first, since it is cheaper than the gauge. If the reading is still near cold, the temperature gauge itself may be faulty.
Conversation Summary
The owner of a 1994 Ford F-150 with 125,000 miles says the temperature gauge stayed near cold during a 300-mile trip and the engine did not overheat. Replacing the temperature switch did not fix it. The expert says the cause is likely the thermostat or the gauge and recommends replacing the thermostat first because it costs less.
