front wheel bearings
FORD
STUDLY0618
My front wheel bearings keep coming loose. I take the assembly apart, retighten the nut, and install all the parts back properly. Then as soon as I go down the road again I can hear grinding again. When I get back, the nut has backed off somehow even with the key inserted.
How does this keep happening?
Dec 14, 2006 at 2:24 PM
CARUNDELL
  • 602 POSTS
[quote:75f6481775="studly0618"]My front wheel bearings keep coming loose. I take the assembly apart, retighten the nut, and install all the parts back properly. Then as soon as I go down the road again I can hear grinding again. When I get back, the nut has backed off somehow even with the key inserted.
How does this keep happening?[/quote:75f6481775]
Hey studly,
Is this a truck? 4X2 or 4X4? or a car?
Chris
Dec 14, 2006 at 8:05 PM
STUDLY0618
It is a 1994 Ford Ranger 4x4 with about 120k miles.
Dec 15, 2006 at 7:41 AM
CARUNDELL
  • 602 POSTS
[quote:3d7f989274="studly0618"]It is a 1994 Ford Ranger 4x4 with about 120k miles.[/quote:3d7f989274]
Hey,
Sounds like the "locking pin" on the inner nut has broken. I recommend you replace the inner nut and be sure to torque this one to spec!
Chris
Dec 15, 2006 at 7:53 AM
