2002 Ford Ranger One-Wheel Nose Dive
PEPSLNUT
2002 ford ranger atuomatic 3.0L 98,000 replaced front callapaiers, new brake hoses still going in to a one wheel noses dive. it all started after replaced emergecny brake cable and rear brake pads, then the front brakes started getting sentive. the master cylnder is 4 years old. could it be the abs system or the portioning vavle.
Oct 10, 2007 at 3:13 AM
MERLIN2021
  • 17,250 POSTS
Check the compensating ports in the master cylinder, have some one step on the brake and watch when the pedal is released if you see some turbulence in the reservoir it's OK, the other possibilty is you kinked a brake hose, check the pads as well make sure they are seated in the caliper mount correctly, I have see sensors under the stainless hardware hang up a pad..
Oct 10, 2007 at 10:19 AM
MERLIN2021
  • 17,250 POSTS
When the wheel locks up, open the bleeder screw, if the wheel turns free get a new flex hose, if not the caplier needs to be changed...
Oct 15, 2007 at 5:24 AM
Suggested Repair
Check the master cylinder compensating ports by watching for reservoir turbulence when the pedal is released. Inspect for a kinked brake hose and confirm the pads are seated correctly in the caliper mounts, including any sensor hardware that could hang a pad. If a wheel locks, open the bleeder: replace the flex hose if the wheel then turns freely; otherwise replace the caliper.
Conversation Summary
A 2002 Ford Ranger developed sensitive front brakes and a one-wheel nose dive after the emergency brake cable and rear pads were replaced, even after new front calipers and hoses. The owner asked whether the ABS or proportioning valve was at fault. The expert advised checking master cylinder compensating ports, possible kinked hoses, and pad seating, then using the bleeder test to decide between a new flex hose and a caliper.
