How do I remove the front caliper? I've removed the rears a million times, but never the front.
Jan 27, 2006 at 6:54 PM
LOVESCARS
✓ASE Certified Mechanic
Essentially the same as rear likey two bolts holding them in place Ford usually utilizes a torx bit to back them out.
If you have done the rear calipers then you know how to do the rest.
Jan 28, 2006 at 9:35 PM
