1997 Ford Escort Front Brake Pin Stuck
Very carefully check the springs, I have seen a ton of them with broken springs, while your at it check the rea ones also even though the noise is not coming from there.
Those front brakes are a hassle. At the very least plan on new hardware, but for $50 you can can a reman caliper with the hardware
I drive the pins out with a thin punch.
Don't forget to remove the cotter!
Suggested Repair
Remove the cotter pin, soak the seized caliper pin overnight with penetrant, then drive it out with a thin punch or grip it with locking pliers and tap it free; heat or light impact vibration can help. Plan on new hardware or a remanufactured caliper. Have a reputable shop recheck the intermittent right-turn knock for a tie rod, ball joint, U-joint, broken spring, or the caliper. Replace the timing belt at 120,000 miles.
Conversation Summary
The owner of a 1997 Ford Escort LX could not remove one front brake pad retaining pin near the brake line and also reported an intermittent knock when turning right quickly. A shop had tightened undercarriage bolts and ruled out a tie rod or axle, but the noise remained. Replies said the pins are often very hard to remove and recommended penetrant, heat, a punch or locking pliers and hammer, and new hardware or a reman caliper. The knock could be a tie rod, ball joint, U-joint, spring, or the caliper, and the timing belt interval given was 120,000 miles.
