I have a 1998 escort and am trying to change rear brakes but can not get them off. Is there a secret way?
Jul 25, 2007 at 11:12 AM
Confirm whether the rear brakes are drums or discs. For drums, back off the brake shoes, remove the two front drum screws with a ratchet and bit, then thread the correct bolt into the small hole to push the drum off the hub.
The owner of a 1998 Ford Escort could not remove the rear brakes. An expert explained that drum brakes have two front screws and a threaded hole used to push the drum off, and that four-wheel disc brakes have no drums. A follow-up said the shoes must be backed off and that a ratchet bit can remove the screws without an impact driver.
