1995 Ford Mustang severe vibration
1995 FORD MUSTANG
91,000 MILES • V8 • 2WD • AUTOMATIC
NICK CANTRELL
Greetings The problem I am experiencing with my car is a severe vibration when started.The motor is running fine, I do not know if this could be a transmission or flywheel problem or torque convertor? Or motor mounts? THe car has on occasion when under hard accelaration missed it's first to second shift and is like you missed a gear with a manual transmission. Any help in this matter would be appreciated
Jan 22, 2008 at 1:43 AM
MERLIN2021
  • 17,250 POSTS
TSB# 97-11-11 for 4R70W tranny states...erratic or prolonged 1-2 shift.
94-97 Mustang and others...Replace the cast aluminum piston with the one piece
stamped steel piston with bonded lip seals and replace the top accumulator
spring. This is due to 1-2 accumulator bore scuffing the revised piston can be
used in the scuffed seal bore.
This may be your problem...
Jan 22, 2008 at 2:00 AM
