1995 Ford Mustang 6 cyl Two Wheel Drive Automatic 150k miles
95 mustang performance problem
It started out that when it got to 20 or 30 it would sputter and backfire lightly and drop back down to 10 miles per hour
Now it will only run like 10 miles perhour
Took it to Advance Auto and they checked the codes it said
Bank 1 and 2 Too lean they told me TPS and mass air flow
Took it across the street they checked it same Bank 2 too lean said it was the EGR valve
Took it to a mecanic he put a gauge on the fuel pressure valve it only had 30 lbs at idle and 18 when you reved it up
All these parts are exspensive Is it possible that all of them are bad at once
Where should I stat what do you recommend
Saturday, June 13th, 2009 AT 12:55 PM
