How an Engine Mount Works
engine mount
How Does it Work?
Engine mounts are designed to isolate the vehicle from vibrations and harmonics created by the engine. Designed by using two metal plates vulcanized together with a sizable piece of rubber or a liquid filled bladder this part is positioned between the frame and the engine. The lower plate is bolted to the frame whereas the upper metal plate bolts to the engine allowing a slight amount of movement from the engine. These mounts are also used for the transmission and perform the same operation.
In a rear wheel drive vehicles there are usually two mounts one on either side of the engine with one mount used for the transmission. Front wheel drive applications may incorporate more mounts to help control engine torque. Front wheel drive vehicles sometimes incorporate a "dog bone” or torque mount to control the twisting of the engine. When an engine mount goes bad it will cause excessive movement from the engine in which case the engine mount will need to be replaced.
Got any Questions?
If you have any engine mount questions please visit our forum. If you need car repair advice, please ask our community of mechanics is happy to help you and it is always 100% free.
We hope you enjoyed this guide. We are creating a full set of car repair guides. Please subscribe to our 2CarPros YouTube channel and check back often for new videos which are uploaded almost every day.
Repair Safety Notice: This guide is provided for general informational and educational purposes only. Vehicle repairs can involve risk of injury, property damage, or vehicle damage. Always follow proper safety procedures, use the correct tools, support the vehicle securely when raised, and consult a qualified automotive repair professional if you are unsure about any step.
