1995 Ford Mustang car wont start
APDNARC
  • 1995 FORD MUSTANG
Electrical problem
1995 Ford Mustang 6 cyl Two Wheel Drive Automatic
My 1995 Mustang ran fine, I parked it came out moments later and tried to start it and it just clicked. All light and gauges work with power but not enough to start it. I jump packed it and it would not start until I moved the ground to the alternator bracket then it started. I changed batteries and the same problem persists. Do I have a weak ground somewhere or what?
Friday, October 30th, 2009 AT 5:20 PM
Do a voltage drop test on the cables if okay check and test the starter relay and starter itself
Friday, October 30th, 2009 AT 10:42 PM
APDNARC
I fixed it, how simple the bolts where the cable attaches to the cable end came loose. It provided enough power to run the lights but not turn it over. Gave each bolt a couple a turns and it started right up. Thank God
Saturday, October 31st, 2009 AT 9:58 AM
