It will start after sitting over night, but as soon as I turn the key off and try to start it again it wont start. It just keeps trying till the battery dies. It also has lost all power when I was driving down the road. It just shuts down and I have to try to get to the side of the road. Please help!
SPONSORED LINKS
Sunday, June 15th, 2008 AT 6:46 PM
MECHANIC
Check the fuel pressure with a fuel pressure gauge designed for your system and comeback with the readings we go from here-
Sunday, June 15th, 2008 AT 7:50 PM
POUNDCAKE412
MEMBER
When I pull the coil wire from the distributer side I have no fire.I replaced the ignition coil and still no difference
SPONSORED LINKS
Sunday, June 15th, 2008 AT 8:24 PM
MECHANIC
Check for input power to the coil/inspect and test the distributor pick-up coil/ignition control module-
Sunday, June 15th, 2008 AT 10:13 PM
POUNDCAKE412
MEMBER
HOW DO U TEST THE DISTRIBUTER PICK UP COIL?
WE CHANGED THE IGNITION CONTRL MODULE AND THE COIL, IT RAN FOR ABOUT 45 MINTUES WE TURNED IT OFF AND IT WOULDN'T START AGAIN. WE WAITED ABOUT AN HOUR AND IT STARTED RIGHT UP.
Tuesday, June 17th, 2008 AT 8:02 AM
MECHANIC
Disregard the pick-up coil
Recheck the ignition coil primary and secondary resistances. Primary should be 0.8-1.6ohms and Secondary=8K-11.5K ohms.
