2004 Ford Freestar front tires
11,500 MILES • 6 CYL • 2WD • AUTOMATIC
JOEJOE
my front tires keep going flat and inside them are cut marks all the way around tire
Dec 18, 2007 at 6:17 AM
MERLIN2021
  • 17,250 POSTS
Do you mean the inner sidewall? or actually on the inner surface as taken off the rim? The first could be sabotage, the second, a manufacturing defect...
Dec 18, 2007 at 7:37 AM
  • 31,937 POSTS
Hi there,
Get the side walls inspected as if the cuts are to deep they will be prone to failure, If ok, the rims may be a bit Rusty where the tyre bead seals and you may need to have them cleaned and possibly return to a tube rather than tubeless fitting, (tubeless tyres can use tubes, so don't get talked into new tyres if you don't need them)
Mark (mhpautos)
Dec 18, 2007 at 7:40 AM
