1999 Ford Explorer Noisy Tire Wear
LTERWIN
My front tires are extremely loud when I take off. When I stop the sound stops, but continues when I start moving. I ran my hands on the tires when I got home and noticed that the front inside tread of the tires was uneven and not smooth. What could be causing the tires to wear like this?
Feb 13, 2006 at 11:25 AM
LOVESCARS
  • 359 POSTS
you may have front end wear have the alignment checked.have tires balanced.
if you want to get rid of that tire noise you'll need to purchase new tires.
Feb 14, 2006 at 10:20 AM
Suggested Repair
Have the front-end alignment checked and the tires balanced. Uneven inside tread wear may be from front-end wear; replace the tires to eliminate the noise.
Conversation Summary
The owner of a 1999 Ford Explorer reports very loud front tires while moving, with the noise stopping when the vehicle stops. The inside tread on the front tires is uneven and rough. The expert attributes this to front-end wear and recommends an alignment check, tire balancing, and new tires to stop the noise.
