2002 Ford Explorer Front Right Tire vibration
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
ADAMSB988
My Sport Trac has developed a vibration while driving,but only when i turn right. I've read some other questions on here but i wanted to know if it was something as simple as a tire out of balance or as expensive as replacing some of the linkage involved up there.
Feb 1, 2010 at 5:30 PM
  • 110,251 POSTS
If you feel it when you turn right, chances are the right wheel bearing is going bad. Is there any noise associated with it? Also, try rotating the tires to see if it changes.
Feb 5, 2010 at 2:52 AM
