My tire on rear left side is bowing in,at the top the tire shows lots of wear, only one tire is doing this the driver side rear tire.
Mar 14, 2016 at 9:44 AM
HMAC300
✓Experienced Mechanic
have this checked for a bent wheel or bent axle or bushing worn on springs or spring shackle mounting.
Mar 14, 2016 at 9:50 AM
CARADIODOC
That would imply you have independent rear suspension and that wheel is out-of-alignment. The angle in question is called "camber". The people at a tire and alignment shop can inspect the suspension system and tell you if there's worn parts or if an alignment is all that's needed.
Mar 14, 2016 at 9:52 AM
WTMITCH
MEMBER
Thank you so very much!
Mar 15, 2016 at 12:14 AM
