1995 Ford Aerostar Tire Pressure
YOSSIAN
Do you know what is the recommended tires air pressure for Aerostar 95 3.0L (the short one) ?
I think there was a recall or a letter about it....
Thanx !!!
Dec 10, 2006 at 6:08 PM
CARUNDELL
  • 602 POSTS
[quote:fe3fb415e4="yossian"]Do you know what is the recommended tires air pressure for Aerostar 95 3.0L (the short one) ?
Thanx !!![/quote:fe3fb415e4]
Hey yossian,
Look at the tires and printed on them is the max tire pressure, usually 35 psi or 44 psi.. but somewhere between 32 and 35 psi is fine
Regards,
Chris
Dec 11, 2006 at 2:41 AM
Suggested Repair
Check the maximum pressure printed on the tire sidewall. A typical operating pressure of about 32 to 35 psi is fine, provided it does not exceed the tire's maximum rating.
Conversation Summary
The owner asked for the recommended tire pressure on a 1995 Ford Aerostar 3.0L short model and mentioned a possible recall or letter. The expert advised reading the maximum pressure printed on the tires and said about 32 to 35 psi is generally fine.
