1994 Ford Aerostar Headlights Quit
KAJ419
I have a 1994 aerostar and the headlights just quit working one day. someone said they have circuit breakers, but i can't find them, so i figure its a bad switch. If it is the switch how do i get the knob off so i can get the dash the rest of the way off to replace it. and is there anything else i might need to know.
thanks
kaj419
Mar 29, 2006 at 6:58 AM
PEPPERMRJ
  • 1,158 POSTS
It doesn't come off. You have to remove the dash trim panel and then the left control pod screws and you will see the 2 screws that hold the switch in. Check your PMs.
Good luck and let us lnow. :)
Mar 31, 2006 at 1:15 PM
Suggested Repair
The headlight switch knob does not come off. Remove the dash trim panel, then the left control pod screws, to reach the two screws that hold the switch.
Conversation Summary
The owner of a 1994 Ford Aerostar says the headlights quit working and suspects the headlight switch after being unable to find circuit breakers. They ask how to remove the knob to finish taking the dash apart. The expert says the knob does not come off; remove the dash trim panel and left control pod screws to access the two screws holding the switch.
