2001 Ford Focus Brake Grind at Speed
MATT420
i have a 2001 ford focus with 89,000 miles and when i brake ait 60 mph there is a grinding sound with a vibration, but at 30 mph and lower it does not do this. i looked at the frount brake pads and rotors and they were fine what else could it be?
Feb 23, 2007 at 12:38 PM
CHEVY22
  • 1,375 POSTS
sounds like the rotors may be warped and there is no way to visually inspect for that , they need to be pulled and put on a brake lathe or on the car with a dial indicator , as far as the grinding , you may have an inner pad on one side or both going metal to metal , whatever you do the longer you wait to have it checked the more cash it will cost you and its a safety issue , hope this helped
jim
Mar 15, 2021 at 12:31 PM
Suggested Repair
Have the rotors measured for warpage with a dial indicator or on a brake lathe, since warpage cannot be seen by looking at them. Also inspect the inner brake pads for metal-to-metal wear. Address it promptly because it is a safety issue and can become more expensive.
Conversation Summary
The owner of a 2001 Ford Focus with 89,000 miles reports grinding and vibration when braking at about 60 mph, but not at 30 mph or lower. The front pads and rotors looked fine. The expert says the rotors may be warped and must be checked on a lathe or with a dial indicator, and an inner pad may be worn to metal. Waiting could raise the cost and is a safety concern.
