2001 Ford Focus Burning Smell
MATT2123
After the car warms up, generally after driving for about 10-15 minutes. I get the smell of what I thought was burning oil, however after checking the oil and everything I am not losing any oil. I started thinking about the breaks and looked and I was very low on my brake or transmission fluid. Can this be the cause of the smell? Is there a specific place a non-mechanical person can check to see if there is a leak somewhere? Thanks.
Jul 31, 2006 at 3:16 AM
TAURUSWHEEL
  • 718 POSTS
If it's a burning smell ,check around your master cylinder and follow the lines, see if any are leaking onto the exhaust,,, most of the time, the lines closely follow the frame and are not exposed to hot surfaces, most of the time... what is the brake ransmission fluid deal??? If your brake fluid gets too low, the brake light should come on,, if your trans is leaking, it very well could end up on the exhaust system,,, put a clean piece of white or other cardboard under your engine rans tonight, check it in the morning for leakage,,, trans will be red,, also don't forget, check your power steering unit for fluid loss, that could also be a source, that fluid will be red also..
Jul 31, 2006 at 9:40 AM
Suggested Repair
Inspect the master cylinder and brake lines for leaks onto the exhaust. Place clean cardboard under the engine overnight to identify any leak, and check transmission and power steering fluid levels as well.
Conversation Summary
The owner of a 2001 Ford Focus notices a burning smell after 10-15 minutes of driving but is not losing oil, and finds the brake or transmission fluid very low. The expert advises checking the master cylinder and lines for leaks onto the exhaust, using cardboard overnight to spot leakage, and also checking the transmission and power steering fluid.
