2004 Ford Focus Black Wheel Grime
J_TOREL
have a 2004 Ford Focus tdci. I have noticed on the front wheels a coat of black stuff that is not normal road grime. We bought the car at a used car dealership. We noticed at that time that there was rust on all the brake discs. We were told that this was normal because the car had not been ran since it had rained the previous week. When we test drove it, the rust came off and they discs looked fine. However, when we bought the car it was negotiated to have them replace the brake pads and discs. Now, the two front wheels have this coating of dirty black stuff after a month of the brake job. I know this isn't normal road grime. What could be causing this? Thanks for your time.
Oct 22, 2006 at 10:52 PM
CATCH_15
  • 250 POSTS
How often do you wash the wheels. If they haven't been washed in a while, it's probably built up brake dust.
Oct 23, 2006 at 2:47 PM
J_TOREL
I found out that thay replaced the pads with super cheap ones. They tend to make more brake dust. Thanks for answering.
Oct 30, 2006 at 9:29 PM
Suggested Repair
Clean the wheels regularly. The black coating is likely brake dust from inexpensive pads, which tend to produce more dust; higher-quality pads can reduce it if the buildup is a concern.
Conversation Summary
The owner of a 2004 Ford Focus TDCi noticed a black coating on the front wheels about a month after the dealer replaced the brake pads and discs. The expert said that if the wheels had not been washed recently, the coating was probably built-up brake dust. The owner later confirmed the replacement pads were very cheap and tend to create more brake dust.
