1989 Ford Falcon
TONY25
1989 Ford Falcon
hi i have a 89 ea falcon i have a problem with the injectors not fireing a wont start, it has power going into the computor but not coming out to fire them . u can start it by turning the key on and pluging another dizzy into the loom and earthing it a turning the sharft a it fires the injectors then plug back onto the car dizzy then the car runs but has a dead spot just off idel any ideas. as i have the car at a electrician and they cant find wots wrong and they have had the car for 5 weeks any help would be great
cheers tony
Jun 19, 2010 at 9:49 PM
  • 31,937 POSTS
Multi point or centre point injection?
mark (mhpautos)
Jun 20, 2010 at 12:24 AM
TONY25
hi its multi point injection
cheers tony
Jun 20, 2010 at 6:48 PM
  • 31,937 POSTS
Have you run with a new distributor and have you check the fast & slow codes in the ECU?
mark (mhpautos)
Jun 20, 2010 at 8:08 PM
TONY25
iv tryed 3 difrent dizzys no difrents made havnt checked codes yet i do have all the code numbers but there isnt a fast or slow code
cheers tony
Jun 20, 2010 at 8:52 PM
  • 31,937 POSTS
If you do a scan you will see that Ford have 2 sets of codes Fast & slow, Fast codes coves hard wear systems and slow code cover sensors and control units, run the scan just to be sure that there are no unresolved fault codes in the system, this will stat the process of elimination for this problem.
mark (mhpautos)
Jun 20, 2010 at 9:06 PM
  • 31,937 POSTS
Forgot to say, with the code check, it will prompt you to do a series of simple procedures, make sure that you do this exactly and ensure that the engine is at normal operation temp.
Mark
Jun 20, 2010 at 9:11 PM
