Computer problem
1994 Ford Falcon 6 cyl Automatic 50000 miles
car cranks over but wont start reset the smart lock still the same
Friday, November 6th, 2009 AT 6:31 PM
MECHANIC
Is it a distributor ignition or coil pack engine?
Mark (mhpautos)
SPONSORED LINKS
Saturday, November 7th, 2009 AT 2:56 AM
GRUBGO
MEMBER
Distributer checked spark to plugs all ok
Saturday, November 7th, 2009 AT 5:36 PM
MECHANIC
If you have spark you should have injection pulse, but just check that anyway, and can you hear the fuel pump cycle? It should run for a few sec then shut off when you turn the key to on, check that next.
Mark (mhpautos)
Saturday, November 7th, 2009 AT 8:44 PM
GRUBGO
MEMBER
Checked fuel pump ok pulse ok cheched plugs dry no fuel any hints
Friday, November 20th, 2009 AT 4:00 AM
MECHANIC
You will have to check fuel rail pressure, if you have rail pressure and injection pulse, you will have fuel into the engine, we must establish fuel rail pressure and confirm injection pulse.
Mark
SPONSORED LINKS
Saturday, November 21st, 2009 AT 1:06 AM
GRUBGO
MEMBER
Mark we removed the injector electics and then replaced and car fired and ran dont know why but thats what happened.
Saturday, November 21st, 2009 AT 8:38 PM
MECHANIC
Hi there,
may have been a problem with a plug connection, any way your running again and that is the main thing.
