2004 Ford F-250 Cannot get my truck to start
RYANJORDAN
  • 2004 FORD F-250
  • V8
  • 4WD
  • 139,437 MILES
I replaced the starter which was bad, I replaced the batterys also. I had my alternator checked and that was good.
But I still cant get the truck to start.
Thursday, October 14th, 2010 AT 4:40 PM
Pick your symptoms below check it and get back with some testing results
Cranks but no start condition:
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
No crank at all/nothing/nada when key is engage to starting position
Could be a blown fusible link, the starter, starter relay, clutch switch/park and neutral switch/transmission position switch a
Thursday, October 14th, 2010 AT 11:45 PM
