Hello -
Well, my main program is not working right now so I am kind of at a stand still since I can not view the wiring diagram.
However, it does look like something is going on there.
Okay, look those connectors and sockets over really good for any burnt, bare wires, chaffing, corrosion, anything. You are getting power from something... That is specific to the left but not the right.....I say this because you can pull the fuses and the right go out but the left does not.
Sorry, I don't show where that Fog lamp relay is right now... You could contact the parts department and see if they can tell you. My thought is that that relay may be acting up since so many things run through it. I think, (I don't have the wiring diagram right now) but I think it has a separate wire that goes to the left lamp. So that is what I am trying to get to.
The other fuses take out the right... But if the relay is bad it may still be getting power and feeding the left lamp. BUT, if I remember correctly fuse 43 and 45 feed the fog relay....... So might the others though.........
Okay, try pulling one fuse at a time and see what happens and leave them out as you go. 7, 14, 19, 43, 45, 46, 47, 30.
If they go out, then turn the light on..... Then back off. Then plug in one fuse at a time in reverse order and the second they come on make note of that fuse. Then, do it again to ensure it is at the same spot.
Then pull all the fuses and then go from the top down...7, 14 etc. So, if say you put in fuse, 30, 47, 46, 45 and the lights come on, remove them and do it again.
Then with all removed put in 7, 14, 19, 43, 45 and the lights come on... Then we know whatever is going through 45 is the problem....... Maybe.
Tuesday, December 9th, 2008 AT 10:47 PM
