1989 Ford F-250 please help
BJWRINKLE
  • 1989 FORD F-250
  • V8
  • 4WD
  • 134,000 MILES
Hello, I just put in a new alternator and selenoid in my truck the other day and now I can't even get the lights to come on. The battery is good everything is hooked up right so I just don't know what it could be. Thanks justin
Thursday, February 11th, 2010 AT 7:45 PM
  • 31,937 POSTS
Hi there,
Best you be checking all the connections at the battery and all the fuses and any fusible links, start with the basics first.
Mark (mhpautos)
Friday, February 12th, 2010 AT 3:09 AM
HOMER1967
  • 875 POSTS
Check and double check all yor connectiuns, check all fuses also try running a new ground wire from radiator support to negative battery terminal. Let me know how it goes. Jeff
Friday, February 19th, 2010 AT 8:43 PM
