1999 Ford F-250 Ford powerstroke diesel "ALTERNATOR&qu
ROBSMACHINING
  • 1999 FORD F-250
  • V8
  • 4WD
  • 147,000 MILES
Does the alternator on these diesel trucks have separate charging systems for each battery. These trucks have 2 batteries. I do know that only 1 batt. Is needed to start the truck. I'm getting 2 diff. Readings while the truck is idling on each battery?
Saturday, January 9th, 2010 AT 5:01 PM
ROBSMACHINING
Ohh no response for any of my two?'S. Huh I guess nobody here is not smart enough to know the answers. WOW thanks youve been so helpful. What a joke this site is, I can tell if you dont offer $$$$$ u get no answer. How LAME!
Wednesday, January 13th, 2010 AT 10:05 AM
MRFIXIT77845
  • 6 POSTS
It wont start on one battery for long or you may get low voltage damage to your starter. Check you cables for inner corrosion do a load test on each battery seperatly one may be bad. My cable corroded of on my secondary battery and had to be replaced I put another cable from the positive bolt on primary to pos on sec hope this helps
Wednesday, January 13th, 2010 AT 9:45 PM
