1986 Ford F-150 Dies After Start
DAZED&CONFUSED
1986 Ford F-150 engine size 302 4wd standard transmission. Hi, I had the heads done on this truck because it was overheated. Now when i try to start it, it wont idle but i keep it alive by giving it more gas. It'll sound good for about 2 min then it will start to sound like its starving for fuel or no spark. Once it dies, i can't start it again for about an hour or two. I have replaced both fuel pumps and had the injectors and pressure regulator tested. My ignition module is good. New plugs and wires. When i hook it up to my code reader i get these following codes.
54 Air Charge temp Signal High -- CKT open
87 Primary fuel Pump Circuit Problem
Does anyone know what these codes mean? I have no idea what a Air Charge temp Signal or a Primary fuel Pump Circuit is. Could These codes be causing my problem? If not, Any idea on where i should start looking. Any help would be great. Thank you so much.
Jan 30, 2007 at 11:34 AM
SERVICE WRITER
  • 9,123 POSTS
54 may be a bad air charge temperature sensor, but the codes can be set from a cooling system problem, improper oil level or air cleaner duct problem.
The other code may be a bad fuel pump relay or wiring short.
Jan 30, 2007 at 12:29 PM
DAZED&CONFUSED
thank you very much. I will look into those immediately.
Jan 30, 2007 at 12:45 PM
Suggested Repair
Check the air charge temperature sensor, cooling system, oil level, and air cleaner duct for code 54. For code 87, inspect the fuel pump relay and wiring for a short.
Conversation Summary
A 1986 Ford F-150 302 will not idle after the heads were repaired for overheating. It runs briefly, then dies as if starved of fuel or spark and will not restart for one to two hours. Codes 54 and 87 are present despite new pumps, plugs, wires, and tested injectors and regulator. The expert says code 54 may indicate a bad air charge temperature sensor or a cooling, oil-level, or air-duct problem, and code 87 may indicate a bad fuel pump relay or wiring short.
