thanks,
kbrad
Test intake vacuum with a vacuum gauge. Expect a steady 17-21 inches at idle. Snap the throttle to about 2500 rpm; vacuum should drop near zero, rise about 5 inches above normal, then return. An unsteady reading may indicate a vacuum leak or lean condition that makes the computer add fuel. Use the gauge instructions or report the readings.
The owner of a 1994 Ford F-150 with a 4.9 six-cylinder says it starts when cold but dies and smokes heavily when given gas until it warms up. Mileage fell from about 21 to 15 mpg, a brief check-engine light stored no codes, and the transmission often shifts hard. The expert recommends an intake vacuum test for a vacuum leak or lean condition and gives expected idle and snap-throttle readings.
