Vehicle Dies
JWH532
  • FORD F-150
I have a 1997 Ford F-150 XL 4.2 L.
I was traveling at 45 MPH when it just died.
It now does not start.
I have no fuel at shreder valve, nor do I have spark.
Does anyone have any idea of what could be wrong?
All fuse are good. Relays not sure.
Sunday, April 15th, 2007 AT 2:29 PM
SHADYSTANG
Did it restart after being left alone for a bit? If so you have the same problem I havein my mustang 1997. I finally found my starter went bad and upon replacing that I am seeing a 12.5 volt read on my starter with the key off. This leads me to my starter relay in which I am hoping it might be. I'll keep you posted on if this works
Monday, April 16th, 2007 AT 9:51 PM
JWH532
  • 6 POSTS
No it does not start yet It turns over great.
Monday, April 16th, 2007 AT 9:54 PM
MERLIN2021
  • 17,250 POSTS
Any power at the ACC side of the ignition switch?
Tuesday, April 17th, 2007 AT 2:54 AM
JWH532
  • 6 POSTS
Since the the radio works when key is in ACC side I would say yes
Tuesday, April 17th, 2007 AT 12:25 PM
MERLIN2021
  • 17,250 POSTS
See if you can find the cam sensor and check the wires out. Same with the crank sensor.
Tuesday, April 17th, 2007 AT 3:42 PM
JWH532
  • 6 POSTS
Problem has been solved. I wound up taking it to shop. They found a dead short in the power to the PCM. A wire in the right rear of engine compartment
got too close to exhaust manifold causing the short.
Wednesday, May 2nd, 2007 AT 9:46 PM
