Rear end noise
KAMP9992001
  • FORD F-150
2000 F150 5.4l v8. I am hearing a noise from the rear end at deceleration generally at highway speeds only. The noise is kind of a growling sound.
Wednesday, February 21st, 2007 AT 6:27 AM
CHEVY22
  • 1,375 POSTS
Hi
there are only a few components that will make that noise,
1 pinion or carrier bearing failure
2 ring and pinion howl
most likely a bearing, the ring and pinion will howl at all speeds over 30mph
if you do have a bearing failure I would reccomned replacing both carrier bearings, pinion bearings and axle bearings and seals, and clean the housing inside real good, metal contamination will kill the new bearings
thanks
Wednesday, February 21st, 2007 AT 6:33 AM
Related General Content
