just purchased this truck.4x4, it run great when I tested it. But once I took it in the freeway over 40 MPH, 3RD TO 4TH gear. There was some knocking in the engine and loss of power! It only happens when I need to put gas for power.
If going straigh 60 to 85mph no problem.
engine light is one code told me running fuel slim. Oxygen sensor 1?.
"i changed sensors 1 and 2 of oxygen sensor, per code" those are on headers and after cathalic conv ones.
"i change spark plug wires and its running stronger" it iddles ok.
I had a friend check the fuel pressure, it show 20pnds to 30pnds? He claimed it is the fuel pump now. What do you think? Thanks in advance
Soo I am about to change fuel pump/fuel filter
SPONSORED LINKS
Tuesday, October 23rd, 2007 AT 4:51 PM
