1997 Ford Mustang Low Idle Knock
AMAN
1997 ford Mustang 118019miles after my last schedualed oil change my car started to knock but it only does it at low idle once above 1500rpms it stops??? and ideas???
Nov 6, 2006 at 3:40 AM
BOOTDOG
  • 665 POSTS
it sounds like either a wrist pin is knocking, which means you'll need to overhaul the engine, or it could be something as simple as a waterpump. if the bearings go bad in the waterpump, the sound can travel through the engine. to check, remove the belt and start the engine. if the noise goes away. then look into checking the waterpump. it wont hurt to check the other pulleys too
Nov 8, 2006 at 1:05 AM
Suggested Repair
Remove the accessory belt and start the engine. If the knock stops, inspect the water pump and other pulley bearings. If the noise remains, a wrist pin knock may require an engine overhaul.
Conversation Summary
The owner of a 1997 Ford Mustang reports a knock at low idle that began after an oil change and stops above about 1500 rpm. The expert says it may be a wrist pin requiring an engine overhaul, or a water pump or pulley bearing, and recommends removing the belt to see whether the noise goes away.
