2001 Ford Mustang High Idle
JAVIMONTES
2001 Ford Mustang V6@ 79,600miles-My car sometimes sputters when i start it up for the first time during the day.I don't know if this problem is also related with my car idling to high after awhile of driving it. Every time I come out of a shift and stay in neutral it does this, at least until I shift into another gear or i come to a complete stop. Ive had this problem for about 2-3 months now and it has just recently gotten little worse(revs alil higher). I wanted to fix the problem myself so i went to Auto Zone. They told me my fuel injection system might need cleaning, so i bought the cleaner and it did nothing. I always use 93 grade fuel. They are supposed have cleaner in them right? Im sure this is affecting my MPG. Im a college student with low cash flow and would rather fix the problem myself. Do you have any idea what this is? Need help please!!!
Jul 11, 2007 at 3:27 PM
2CARPRO JACK
  • 11,533 POSTS
Check all hoses for vacuum leaks first. If no vacuum leaks are found, I would try an Idle Air Control Valve
Jul 12, 2007 at 7:39 AM
Suggested Repair
Check all vacuum hoses for leaks first. If none are found, inspect or replace the idle air control valve.
Conversation Summary
A 2001 Ford Mustang V6 with about 79,600 miles sometimes sputters on the first start of the day and idles high after driving, especially in neutral after a shift, until another gear is selected or the car stops. Fuel-injection cleaner did not help. The expert advised checking all hoses for vacuum leaks first, then trying an idle air control valve if no leaks are found.
