High idle
HEVYRACING
Ford, Mustang GT(5-speed), 2001, 70,000. My wife just bought this mustang in April. The car appeared to be pretty close to mint condition. It is now September and the car is still in great condition and runs great but wont return to a normal idle. After normal driving conditions it will stay at 2,000-3,000 rpm's when the clutch pedal is depressed and in nuetral. No check engine light is on or anything. It just had an oil change about a month ago thru the dealer. The only other thing i have done to it is change the filter to a K&N. Just the filter. Any suggestions. I have no clue.
Sep 8, 2006 at 8:51 AM
CODYPAUL1
i have been having the same problems i have a 2003 mustang mach 1 w/ 68000 mi. and when i press the clutch it will stay at whatever rpm i pressed it at i was just wondering what it is you done adout it if anything because i am stumped i have changed iac motor/mas filter and cleaned my throttle body with a toothbrush
thanks
cody rivere
Oct 3, 2006 at 8:56 AM
BUBBA_KOSKI
  • 129 POSTS
well it shant be the mass air flow sensor unless the engine light came on, check the clutch cable as well with the slave cylinder
________________
ASE certified
advance auto
9289
Oct 4, 2006 at 7:55 AM
