1987 Ford Mustang High Idle
STACYP
  • 15 POSTS
I have a 1987 Mustang GT. The Engine is idling @ 2000 RPM. How can I adjust the idle speed. It is fuel injected.
May 22, 2007 at 2:46 PM
RUDPRO
  • 224 POSTS
If your car is fuel injected, you probably have a vacuum leak or a bad idle control valve. Check for proper vacuum with a vacuum gauge and check the vacuum lines for leaks. If that's OK, it might be the idle air control valve, or I think Ford calls it the air bypass valve. It should be mounted on the side of the throttle body and it has 2 wires going to it. I'm not very familiar with your car but if the valve is the same as on other Fords, I could tell you how to check with an ohmmeter. What size engine do you have?
May 22, 2007 at 7:21 PM
STACYP
  • 15 POSTS
It has a 302 Engine. I did not find any vacuum leaks and when I unpluged the idle air control the idle dropped down to around 900 rpm.
So I would assume this is my problem, correct?
May 23, 2007 at 7:17 AM
RUDPRO
  • 224 POSTS
It could be the idle air bypass valve or a few other things. To check the air bypass valve. Unplug the electrical connector on it. Put an ohmmeter on the 2 prongs on the valve. It should read between 7-13 ohms. You have to put the ohmmeter leads on the right way, the valve has a diode in it. The positive lead of the ohmmeter should go on the prong closest to the throttle body. Try it both ways. If it reads OL(overload) both ways the valve is bad. If it reads OL one way and you get a reading of ohms outside the 7-13 ohm range it's bad. If it checks good it could be the O2 sensors or the MAP sensor or throttle position sensor. They all give data to the computer to adjust the air bypass valve. You might want to try changing the bypass valve anyway, it probably is the problem
May 23, 2007 at 6:10 PM
Suggested Repair
Test the idle air bypass valve with an ohmmeter: it should read 7-13 ohms with the positive lead on the prong nearest the throttle body. Replace the valve if it reads open both ways or outside that range. If it tests good, check the oxygen sensors, MAP sensor, and throttle position sensor, which control the valve.
Conversation Summary
The owner of a 1987 Ford Mustang GT with a fuel-injected 302 reports idle around 2000 RPM. The expert suggested a vacuum leak or a faulty idle air bypass valve. The owner found no vacuum leaks, and unplugging the valve dropped idle to about 900 RPM. The expert explained a 7-13 ohm diode-sensitive resistance test and said a bad valve should be replaced; if it tests good, the oxygen, MAP, or throttle position sensors may be at fault.
