horn stuck honking
FORD F-150
CHARLIE NEVZ
The horn on my '84 Ford f150 gets stuck honking or blows the fuse while I'm honking. What is the problem and how can I fix it?
It doesn't have cruise control or tilting steering wheel.
Oct 3, 2007 at 8:08 AM
[quote:a26ecade77="charlie nevz"]The horn on my '84 Ford f150 gets stuck honking or blows the fuse while I'm honking. What is the problem and how can I fix it?
It doesn't have cruise control or tilting steering wheel.[/quote:a26ecade77]
Inspect/Test the horn relay-if it checks out-remove cig. lighter do a continuity check between the contact and ground any reading the yellow and light blue is shorted to ground.
The yellow and light blue powers the horn and lighter.
Oct 3, 2007 at 8:45 AM
