F150 4x4 Problems
KAMP9992001
I have a 2000 F150 4x4 with a 5.4L V8. It has 236,000 miles and is in decent shape. I have recently had some trouble with the four wheel drive not engaging, I have changed the shift motor on the transfer case and that did not cure it. The transfer case is shifting now but it seems that the hubs are not. I did find the vacume axle lock and it seems to move fine into 2 wheel drive but when you try to engage 4 wheel drive it doesn't seem to move far enough to engage the hubs. I guess my question is can the vacume motor be repaired or should I just buy a new one or could it be the hubs are bad?
Feb 20, 2007 at 5:49 AM
VW200486
dude the first thing i do when i buy a 4x4 is get rid of those junk automatic hubs. and if you were to buy new automatic one there twice the money as lockouts. but puting lokckout hubs on it i think should cure it
Feb 20, 2007 at 6:01 AM
CHEVY22
  • 1,375 POSTS
[quote:d9dc6f6f48="kamp9992001"]I have a 2000 F150 4x4 with a 5.4L V8. It has 236,000 miles and is in decent shape. I have recently had some trouble with the four wheel drive not engaging, I have changed the shift motor on the transfer case and that did not cure it. The transfer case is shifting now but it seems that the hubs are not. I did find the vacume axle lock and it seems to move fine into 2 wheel drive but when you try to engage 4 wheel drive it doesn't seem to move far enough to engage the hubs. I guess my question is can the vacume motor be repaired or should I just buy a new one or could it be the hubs are bad?[/quote:d9dc6f6f48]
hey camp you cannot repair them , if you found that was your problem , go ahead and replace it , anything else let us know
jim
Feb 20, 2007 at 7:14 AM
SERVICE WRITER
  • 9,123 POSTS
I'd keep the system the same as well. I don't know if our systems are the same exactly, but I have has a bit of a rust build up on the tubes going to the hubs, right at the wheels. I had to pull them off, clean them and reseat them to stop the vacuum loss.
Feb 20, 2007 at 9:15 AM
