1997 Ford F-150 Lacks Power
TRAMMELL503
1997 f-150 258,000 miles but rebuild at 135,000. The problem started a couple weeks ago. Sometimes when I would acllerate I had to put the pedal all the way to the floor in order to get any kind of momentum. I took it to the ford dealer and they said it was the catalytic converters. replaced them. runs somewhat better but still lacks power. with the ac on it really bogs down. I have replaced 2 of the o-2 sensors the maf. also when you race the engine in neutral and let off the gas it will backfire. I know the dpfe needs replacing. but the ford mech said that would not cause my problem. It runs the same whether the shorting bar for the pcm is in or out. when this first started it would only do it for a second then run fine. Any advice would be greatly appreciated.
Aug 9, 2007 at 9:08 AM
2CARPRO JACK
  • 11,533 POSTS
Have you checked the fuel pressure? Has the filter been replaced recently?
Aug 9, 2007 at 9:34 AM
TRAMMELL503
fuel pump and filter have been replaced. also engine run s good when cold, and also at higher rpm and during about 30 seconds after start up. I'm sorry this is a 4.2L engine thanks for your patience.
Aug 10, 2007 at 10:28 PM
2CARPRO JACK
  • 11,533 POSTS
Be nice to get it on a scanner to see if you have a TPS that is going out.Did it have any codes pertaining to the TPS?
Aug 12, 2007 at 1:35 AM
ROLLBAR
  • 12 POSTS
Just a reply. I also have a '97 F-150 & it was doing the same thing then quit. Came out to be the fuel pump. Since U already changed it out I would agree it could be the TPS. AZone will put it on the scanner for free, @ least it's a start, that is if it's trowing a code.
Aug 12, 2007 at 1:39 PM
Suggested Repair
Scan the truck for throttle position sensor codes and test the TPS, since the fuel pump and filter were already replaced and power loss remains.
Conversation Summary
A 1997 Ford F-150 4.2L with high mileage lacks power under acceleration, bogs with the A/C on, and backfires when the throttle is released in neutral. It runs better when cold, at higher RPM, and briefly after startup. Catalytic converters, two oxygen sensors, the MAF, fuel pump, and fuel filter were already replaced, and a DPFE issue was not considered the cause. The expert recommended a scan to check for a failing throttle position sensor, and another owner agreed and suggested a free code scan.
