1988 Ford F-150 No Start No Power
Suggested Repair
Check for a parasitic battery drain by measuring current between the battery and the disconnected positive cable, then pull fuses to find the circuit drawing current. Also inspect fusible links and, once the truck starts, confirm alternator output is about 13.9 volts. A drain is more likely if the battery dies overnight; an alternator or fusible-link problem is more likely if the lights dimmed and the battery failed while driving.
Conversation Summary
A 1988 Ford F-150 with a 6-cylinder engine and 275,000 miles will not start and has no click, lights, or radio after a recent battery replacement. The expert suggested testing for a battery drain with an inline ammeter and isolating it by pulling fuses, then checking fusible links and alternator charging voltage of about 13.9 volts once running.
