2002 Ford F-150 Loses Power on Hills
JUSTINWGRIMES
2002 F-150, 4x4, 5.4 triton 88,000 miles. I had a new motor put in about 3000 miles ago. The other day after I got gas the check engine light came on but I did not notice any problems. Yesterday I was at about 1/4 of a tank and the truck ideled rough until it had warmed up for about five minutes and then ran fine. On the way home from work it was running fime until I started up a hill and the transmission downshifted and them the truck lost power and missfired. The truck ran fine after that until another hill and the same thing happened. When I got into town I filled up thinking it was just bad gas, but on the way to work it happened again. The fuel pump and filter were replaced when the motor was put in. What could be the problem. I live in a remote area and there are not very many mechanics around.
Apr 27, 2007 at 7:31 PM
MERLIN2021
  • 17,250 POSTS
It sounds like a fuel problem, I would ge a pressure test. Also check the pressure regulator on the fuel rail.
Apr 27, 2007 at 8:22 PM
BLACKOP555
  • 10,386 POSTS
I would check and make sure the wires going ot the connector on the fuel pump are securly in place. also clean your air filter and throttle bore
Apr 28, 2007 at 1:12 PM
MERLIN2021
  • 17,250 POSTS
Ford thottle bodies are coated with teflon...don't use spay carb cleaners! And let me know if you find wires going to the fuel line...
Apr 28, 2007 at 2:21 PM
BLACKOP555
  • 10,386 POSTS
fuel pump** eeek fixed
Apr 29, 2007 at 1:04 AM
Suggested Repair
Test fuel pressure and inspect the fuel-rail pressure regulator. Confirm the fuel-pump connector wires are secure, clean the air filter, and carefully clean the throttle bore without spray carburetor cleaner because Ford throttle bodies have a Teflon coating.
Conversation Summary
A 2002 Ford F-150 with a recently installed 5.4 engine ran poorly after fueling: the check-engine light came on, it idled roughly until warm, and it lost power and misfired on hills after the transmission downshifted. The fuel pump and filter had already been replaced. Experts suggested a fuel-pressure test, inspection of the fuel-rail pressure regulator and fuel-pump connector wiring, and cleaning of the air filter and throttle bore without carburetor-cleaner spray.
