2000 Ford Focus Bogs at WOT
JTANDERSON
2000 Ford Focus 104,000 2.0L Zetec
Whenever I accelerate hard from a dead stop, the engine acts like it's gasping for breath. The car just sort of lunges but doesn't go anywhere. The tach bounces from idle to about 1500. I have an aftermarket intake with a reoilable filter. Could this be the cause? I've found a new dry flow filter and am willing to try it. Is my MAFS dying? The fuel pump has been replaced twice. I've had this problem for quite some time and no one has been able to give me a good answer. Thanks in advance.
Jan 25, 2007 at 6:51 PM
  • 75,988 POSTS
Try the MAF and TPS
The TPS signal is used by the PCM to enrich the fuel mixture during acceleration, and to retard and advance ignition timing. The MAF is used by the PCM to measure engine load. These sensors work hand in hand. A leak past the MAF will not be measured therefore the PCM will not adjust fuel demand accordingly.Further a bad signal from the TPS will at times cause the MAF to react.
It operates just like the MAP sensor and in a Carb system its the main metering/power valve circuits.
BTW you might want to check the EGR for opening too soon when not wanted and also it drives the O2 sensor crazy is to how to adjust the A/F mix.
HTH, Good LUck!
Jan 25, 2007 at 7:51 PM
2CARPRO JACK
  • 11,533 POSTS
rasmataz made some excellent points, why has it had 2 fuel pumps? If im not mistaken that is a returnless fuel system, meaning the PCM varies voltage to the pump according to throttle and load.Need to have a fuel pressure gauge on it to see if it varies with throttle and load. But that doesnt mean the PCM is bad like rasmataz said the MAF and TPS have to do with it as well.Not trying to confuse you, just want all bases covered
Jan 25, 2007 at 11:38 PM
JTANDERSON
I've already replaced the TPS once. The fuel pump was replaced once for being faulty and another time due to a factory recall. I'm a little confused as to what you guys are suggesting. There was a lot thrown out in those two posts. Thanks.
Jan 26, 2007 at 2:41 AM
MATHIASO
  • 1,209 POSTS
check your MAF .
Jan 27, 2007 at 12:36 AM
Suggested Repair
Test the MAF sensor and check for unmetered air leaks past it, especially with the aftermarket intake. Confirm fuel pressure changes with throttle and load, and check whether the EGR opens too soon. The TPS was already replaced.
Conversation Summary
A 2000 Ford Focus 2.0L Zetec bogs and lunges when accelerating hard from a stop, with the tach jumping from idle to about 1500 rpm. The owner has an aftermarket intake and reoilable filter, has replaced the TPS, and has had the fuel pump replaced twice. Experts recommend checking the MAF and TPS together, looking for leaks past the MAF, verifying fuel pressure under load, and checking the EGR for opening too soon. The final suggestion is to check the MAF.
