1997 Ford F-150 White Smoke From Vents Fix
ANGELMAN11
I have a 97 ford F150 V8..5.4 L.....while I'm driving there is a light white smoke coming out my vents even tho the air is not on...when turning the air on more smoke comes...its weird smell too....after da car is park for a bit ders a leak of a green fluid...is that a cause of it or diffrent thing.....thanx
Oct 2, 2007 at 5:28 AM
BLACKOP555
  • 10,386 POSTS
2 words. heater core. it is leaking and evaporating causing the nice white smoke that smells like antifreeze to be coming out and probably a thin film of antifreeze on the window.
Oct 2, 2007 at 7:58 AM
Suggested Repair
Inspect and replace the leaking heater core. Coolant evaporating from the core can enter the vents as white vapor with an antifreeze smell and leave a film on the glass; the green fluid is likely coolant from that leak.
Conversation Summary
The owner of a 1997 Ford F-150 5.4L reported light white smoke from the vents even with the A/C off, more smoke when the air was turned on, a strange smell, and a green fluid leak after parking. The expert identified a leaking heater core, with evaporating antifreeze causing the smoke, smell, and a thin film on the window.
