White smoke gas smell
100,000 MILES • 4.2L • 6 CYL • 4WD • MANUAL
WAYNE BONDS
Swapped engine with automatic 1999 150 in my 1997 manual all sounds good. Just white smoke with gas smell from exhaust since it began running.
Mar 11, 2017 at 5:41 PM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge auto parts rent it. it may be pressure regulator is to high . also, check for a blown head gasket although if it just does it should be driven a bit to see if it clears up as it may. See link.
Mar 12, 2017 at 12:46 AM
