1991 ford f150 2wd 4.9 5sp where is the clutch adjustment
Mar 19, 2007 at 7:01 AM
TAURUSWHEEL
✓Experienced Mechanic
I know on some of the cars with mechanical clutches, you have to hook your foot under the clutch pedal and lift it up, there was a type of ratchet system built into the pedal, not sure if yours is this way... if hydraulic not mechanical, isn't it a self-adjusting clutch???
Mar 24, 2021 at 5:21 AM
INDYUKE
The type of clutch you have is hydraulic and it is self-adjusting. If you have a suspicion that it isn't working to it's fullest, change the fluid and bleed the system.
