I have a 95 F150. I need to chance the air charge sensor. Does the intake need to be removed to do this? Thanks, David.
Mar 25, 2006 at 2:42 PM
The intake does not need to be removed to replace the air charge sensor. Replace the sensor at its installed location using the applicable location and replacement procedure.
The owner of a 1995 Ford F-150 asked whether the intake must be removed to replace the air charge sensor. The expert said no and pointed to the sensor location and replacement instructions.
