Ford F-150
SAZYKD
  • 1915 FORD F-150
I have a Ford F150 4.2L 6cyl. With 200,000 miles on it. I have 3 trouble codes which state:"Lack Of Upstream Heated O2 Sensor Switch, Sensor Indicates Lean (bank#1), and System to Lean (bank#1), and System to Lean (bank#2). I am assuming I need to replace my O2 sensor, But, I do not know what
( bank#1) or (bank#2) means.
Can anyone clear this up for me? Thank you in advance. Kimmie
Tuesday, October 30th, 2007 AT 1:25 PM
MERLIN2021
  • 17,250 POSTS
When the 02 sensors don't switch fast enough, it set the code and turns on the MIL, this can happen for bad sensors, or bad gas! Try a tank of 89 octane, get the light turned off and see if it resets, if the light comes back on Bank 1 sensor 1 is the 1st sensor on the #1 cylinder side of the motor, bank 2 is cly #2 side. If you stand at the drivers side at the wheel well and look at the valve covers, the cover that is the most forward is the #1 cyl side!
Tuesday, October 30th, 2007 AT 3:44 PM
SAZYKD
Thank you Merlin, I"ll try the higher octane gas then reset the computer. And I appriciate you explaining bank1 and bank2 for me also. I'll let you know how I did. I am not a machanic, but I do like to get to know the vehicles that I drive machanically, in case I were to break down on the road, I would like to be able to fix it myself. Independant, or driven, I don't know but it works for me. Thank you again.
Kimmie from Cali
Tuesday, October 30th, 2007 AT 5:39 PM
